Old 10-Jul-2018, 6:55 PM   #26
JoeAZ
I seriously hope you can receive satisfactory reception from your attic.
Unlike most other areas, in Arizona many homes have tile roofs. Those
tiles are made of concrete. Concrete blocks radio and television signals
as well as other signals. Most stucco homes have concrete and a chickenwire
sublayer for strength. Both of those also block signals from entering
the home. I've used the GE 29884 several times with good results.
It might be used in your attic but if it doesn't work well there, it is small
enough to be hidden from view from the front of your home. One small
note: The GE 29884 needs to be adjusted not only side to side but up
and down as well. A few degrees tilt up or down can make all the difference
with that antenna. Hope this helps.
Joe in Prescott, AZ
