Old 25-Jun-2018, 1:05 PM   #17
JoeAZ
Hello there Rabbit and I think it's easier for you to get the Winegrud yes the slellar labs.
30-2475 are a hi vhf ANTENNA and I have two of them stagger stacked with 2 of
The same 91,that you have of one know I will explain my hole antenna set-up and
Experience,which was quite fun!I have 2 91 stacked side by side 3ft apart,with my
30-2475,hi vhf,stagger stacked when you put the two ANTENNAs meaning they
Should be 3ft apart forum one another when a uhf,vhf!antennas are put together
My ANTENNAS are on a 150ft tower receive of 1500miles away and the higth of the antenna makes a big improvement of your receive of channel's to and I almost forgot
A good mast mount amp is better too help pull in the distance channels and too STOP
Over load keep you ANTENNAs away frum your strong signals tower's well good luck with your antennas and be safe on the roof and look out for power lines with tv antennas!!!
Thank goodness we have NASCARKEN to keep everything straight!
