Old 25-Jun-2018, 1:30 AM   #16
Originally Posted by upks View Post
Tower Guy mentioned putting the two antenna's together with a rca preamp-1r preamp. Would this be a substitute for the UVSJ UHF/VHF combiner (AKA Diplexer) rabbit mentioned?
Just wanting to make sure I am going to order the correct things the second time.
Thanks!!!
Yes, if you use the RCA TVPRAMP1R preamp, you do not need the UVSJ. Set the antenna switch to separate.
