K35CU, if it's on the air, is probably getting clobbered by adjacent channel KCHA.
KXII will not be receivable with a UHF antenna such as you have. You will need a deep-fringe high-VHF antenna plus steep FM filtering to pull that one out. You're also likely getting strong adjacent channel interference from KETA.
Neither look likely or promising.
