Old 29-May-2018, 1:47 PM   #5
tsigwing
hello, tsigwing
Your TVFool report is no longer on the server:
KXAS is moving from channel 41 to 24 on Wed May 30th. My guess is that they are running with reduced power so that the antenna crew can work safely on the tower with the new antenna.
https://www.rabbitears.info/market.p...&callsign=KXAS
https://www.google.com/search?source....0.hj26vIjlsO8
https://www.nbcdfw.com/news/local/Ho...476697693.html
Hopefully you are correct. This morning I checked again and two of the three meters were in the green, with the other bouncing between the green and yellow. Picture was perfect.
tsigwing is offline   Reply With Quote
