Old 25-May-2018, 3:18 PM   #15
rickbb
Originally Posted by shoman94 View Post
I don't know. I'm aimed at about 10 degrees and attached are the channels I get. This antenna had a pretty wide pattern. I thought about getting a db8e and offset the panels but, it's a bit large.
26 has been giving me some trouble as well coming from the back side.....
Did you remove the reflector to allow for reception from the back? If not that may help improve rear reception, but may lower front side gain.
With a 60 degree beam width I have my 4bay aimed slightly off from the main tower directions and it helps pick up all those channels from the side. Similar to what you have done. The 8 bay has more gain but a much narrower beam width, so may not be what you want.
