Old 22-May-2018, 11:50 PM   #12
Nascarken
Banned
DB4,e
You do have two FM transmitters from the ENE only 3.2 miles away, but they don't look like a serious threat because they are not high power.
http://www.fmfool.com/modeling/tmp/2...2/Radar-FM.png
Yes, worth a try because Fox is much weaker than the rest of your desired channels. Also, if you can borrow a radio that tunes the aircraft band, it is on VHF much closer to TV frequencies.
How do you cover so many different directions with just the DB4e?
You don't just get a real antenna.
