Old 22-May-2018, 7:54 PM   #11
You do have two FM transmitters from the ENE only 3.2 miles away, but they don't look like a serious threat because they are not high power.
http://www.fmfool.com/modeling/tmp/2...2/Radar-FM.png
Rabbit73's suggestion regarding the AM radio might help, but if the noise is restricted to only one UHF channel, it may not be sufficiently broadband to register down in the AM band. It is worth a try, though.
Yes, worth a try because Fox is much weaker than the rest of your desired channels. Also, if you can borrow a radio that tunes the aircraft band, it is on VHF much closer to TV frequencies.
Originally Posted by shoman94 View Post
I find it hard to believe that it's a signal problem when like clock work it's 18 seconds. Aiming the antenna doesn't fix it.
Thoughts?
AD d4be, AD preamp, SD hdhomerun connects
How do you cover so many different directions with just the DB4e?
