Old 22-May-2018, 12:59 AM   #3
shoman94
What channel (real)?
Do you live in a rural (or semi-rural) location where you or a neighbor might be using an electric fence for livestock, or other critters? Dog containment "invisible" fence?
Channel 23 (real)
2.7NM(db) I can move the db4e a good 15 degrees and have the same signal. 90% with signal quality in the 60's.
No dog fences or anything right around me.
EDIT: Right now the signal is peaking at 94% and SQ is high 60's to low 70's.
I do have new 600MHZ tmobile towers in the area.
I just installed an FM filter right in front of my Power inserter and either it helped or the sun going down is helping. If it stays improved I'll move the FM filter at the antenna.
