Old 18-May-2018, 1:34 AM   #4
Welcome to the forum, raym
Thank you for the report and the photo
Trees wiil block TV signals, but it is difficult to predict how much.
TVFool is using a defective database, so there are some errors in your report:
The list of channels from a rabbitears.info report is probably more accurate, but there are many changes going on because of UHF Repack by the FCC which will limit UHF to 14-36.
WTVD will be moving to real VHF High channel 9
https://www.rabbitears.info/market.p...&callsign=WTVD
WNCN will be moving from UHF channel 17 to VHF-High channel 8
https://www.rabbitears.info/market.p...&callsign=WNCN
WRAL from 48 to 17
https://www.rabbitears.info/market.p...&callsign=WRAL
and WRAZ from 49 to 15
https://www.rabbitears.info/market.p...&callsign=WRAZ
It looks like they will be in the same direction. You will need a UHF/VHF combo antenna like the Winegard HD7694P or 7698P. You might need a preamp, but try it first without.
