Old 11-May-2018, 5:56 PM   #15
Nascarken
Banned
You should probably tack a good look at the 91xg!!
I'm sorry, I'm still confused. There's nothing on or about our antennas that we refer to by "AGL". The only term associated with antennas that might be reasonably abbreviated as "AGL" that I can think of would be "Above Ground Level". This, of course, has nothing to do with any particular feature of any particular antenna but instead refers to where the user chooses to fasten the mast clamp to the mast or a height above ground the entered into a simulator for the purpose of making calculations regarding signal propagation.
If you could be clearer or more explicit with your question using commonly used and accepted terminology, I might be able to better answer your question or concern.
Well you have got it all wrong some Teck. I think you should quit while you're a head. but not by much lol take a close look at the 91xg when you take it out of the BOX!!!! And a close look at the tv Fool report agen higth 10ft AGL45. ask
Rabbit 73 what AGL is.thank you have a good day!!!!
