Old 9-May-2018, 1:56 PM   #2
jrgagne99
You'll probably only get NBC on one of the two VHF-hi options (WILX or WOOD). WEYI-NBC (UHF) is likely too weak for an attic installation. Everything else on your list is on UHF. I think I would try a Clearstream 2MAX or 4MAX aimed at 175-magnetic. The thought being that the VHF-dipole will pick up real 10 (WILX-NBC), the channels to the east are strong enough to receive on the side lobes, and you'll get FOX off the back since there is no reflector on that antenna. Start simple (1 TV, short coax runs), and you'll probably need to spin it around and rescan many times until you have it dialed in. I have heard antenna installs are a cr-shoot. Hopefully, you wouldn't need a dedicated VHF-Hi antenna solely for NBC.
