I am guessing you have your antenna pointed north which may drop that high signal station to the south enough that you can use a weak amplifier like a RCA 20db amp
you didn't say if you get channel 7 if you do and don't get 13 that is a problem
your signal is theoretically good but there is something that you should check out
go to rabbitears.info and find your stations.. then find that channel 13 .. use the dropdown to see your technical data.. and if they show a map they may show the direction that channel 13 is broadcasting...
if they show that the broadcast tower is pointed away from your direction but they are stating that the tower puts out enough power to reach you then this may be a problem
also vhf kinda sucks
