Another thought just crossed my mind. Maypo should check the connectors on the coax first to see if they are tight. I just took down a antenna at my house and found that two of the connectors had become loose at the antenna and pre amp. That can impact weaker signals if you don't have a good connection. Use some Botch 33 tape and then something like Coax Seal or Botch 2228 over the 33 to seal it well from the elements. It will also help keep the coax more secure if it is properly taped. I made the mistake of not taping it properly and now with the new antenna, I have the connectors sealed better.
