Old 18-Feb-2010, 6:26 PM   #2
mtownsend
Originally Posted by gtrippleb View Post
From looking at the tvfool report, it looks like I wouldn't need a high power antenna if I read the report correctly.
Hello and welcome!
You have an interesting situation, indeed. Your signals are medium strength, but come from opposite sides of the house. The stations are almost exactly 180 degrees apart. You don't need a whole lot of gain to get these channels, but the problem is that if you aim an antenna at one of the markets, you won't get much signal from the other market (because the "back" side of the antenna would have very low gain) and vice versa.
You could install an antenna rotator. This would let you get channels from either market, but only one at a time. It also gives you the option of viewing channels in other directions, including a shot at a few stations out of Roanoke and Myrtle Beach if you go with a bigger antenna.
The other option is to install back-to-back antennas pointing at both Greensboro and Raleigh. This reduces the effective gain of each antenna (which should be OK because of the good signal strengths), but it makes it possible to receive both markets simultaneously without having to touch anything.
it looks like I would be fine with an antenna that can receive channels 7-51. This is if I read the report correctly. Going off of this information, it looks like I could use the following antennas:
Channel Master 4228HD
Channel Master 3016
Channel Master 2018
Channel Master 2016
What I'm going to suggest may sound a little strange, but I think it will actually work well:
- Get two CM 4221HDs
- Install them back-to-back at the top of a mast
- Using two short identical lengths of RG6, connect them together using an ordinary 2-way splitter/combiner
- Get a Winegard YA-1713 or Antennacraft Y10-7-13 (high-VHF Yagis)
- Install the high-VHF Yagi about 4 feet lower on the mast
- Combine the UHF feed and VHF feed through a UVSJ combiner (cable lengths do not need to be identical for this part)
- Send the single combined feed into the house
- DO NOT use any pre-amp or antennas with built-in amps
- Mount the mast on the roof with the VHF Yagi and one of the CM 4221s pointed at Raleigh, the other 4221 should be pointed at Greensboro
Here's the reasoning behind these choices:
> I think the added gain of the 4221 (compared to the smaller 4220) will help improve signal reliability. You lose a bit of antenna gain when combining antennas, you have some trees to shoot through, and you won't have a pre-amp, so I thought the extra gain in the antenna would help compensate in all three regards. The CM 4228 has only a tiny gain improvement over the 4221 and adds way too much weight and bulk to be used in this way.
> You'll need the high-VHF Yagi to deal with WTVD (ABC, ch 11). You can also use the smaller versions of these Yagis (Winegard YA-6713 or Antennacraft Y5-7-13).
> The UVSJ combines separate UHF and VHF inputs more efficiently and with less interference than a standard 2-way splitter/combiner. It's the best way to combine signals from different frequency bands. Since the two 4221s are in the same frequency band, you must use a standard 2-way splitter to join them before going to the UVSJ.
> You have two very strong local transmitters that are strong enough to cause concern for amp overload. An overloaded amp can make things worse rather than better. To avoid that possibility altogether, just don't use an amp. With good starting signal strengths and good antennas, you don't need the amplification.
> With this setup, you avoid the need for a rotator. This lets you enjoy channels from two markets without having to touch anything. It is especially helpful for unattended recording of programs (DVR).
