RCA ANT800 Panel Antenna
I might be at a bit of a loss regarding the mounting / orientation of this antenna.
The manual's exact wording is "the antenna usually works best when mounted horizontally"
So I am taking the word "mounted" and thinking "side of the house" with the panel facing out, flat side pointed in the direction I am concentrating on.
But when I look at some pictures, it may appear that the antenna itself almost seems to be angled horizontally (like a floating plate) rather than vertically which is the way I picture a panel antenna operating.
Regardless, each position offers unique reception capabilities, but in practice does anyone know what the actual correct orientation is, as there is also an adjustment to rotate the panel left or right by a few degrees.
Thanks,
TM
