Old 13-Apr-2018, 10:57 PM   #25
Originally Posted by TX1228 View Post
Thank you both for your time and recommendations. I also appreciate the advice for a mounting method. I'll start with this and see what happens.
If I do have to put in a filter to reduce the ION channel strength would that antenna still be sufficient to reach the other channels down that bearing that are approximately 50 miles out?
Reducing the strength of WPXC ION should make it possible to use a preamp to make it easier to receive your weaker signals, but I can't guarantee it; you must be willing to experiment.
