Old 13-Apr-2018, 2:38 PM   #24
Hello again, TX1228
Which channels are giving you a problem?
Are you splitting the signals for more than one TV? If you are, are those channels better on just one TV without the splitter?
Do you have a signal strength indicator on your TV to give you an idea of how weak a signal can be and still be received?
Is your coax grounded with a grounding block that is connected to the house electrical system ground?
Did you try the Channel Plus NF-471 Notch Filter with and without a preamp as suggested earlier?
