WLVT went off the air and is now channel sharing on RF channel 9.
Did you really buy RG-8? That is 50 ohm coax and better for transmitters than TV receivers.
As JoeAZ said, you would do well with a full-sized all channel antenna aimed at Philly. It would be possible to add WPVI to your HD 7698P antenna using an HLSJ. Additionally, you could split the Philly all channel antenna before you insert the HLSJ and have WPVI with both the NYC antenna plus the Philly antenna.
