Thread: VHF High 13
Old 23-Mar-2018, 7:28 PM   #2
Hello, Geezer64; welcome back. I see you have been here before; your previous threads for reference:
Advice in Eastern NC 5-Aug-2014
http://forum.tvfool.com/showthread.php?t=14724
To switch or not to switch 4-Sep-2014
http://forum.tvfool.com/showthread.php?t=14845
Thank you for the TVFool report. It's only resolved to block level, but it might be close enough.
I see that you have a different antenna now. The dipole for the CS4MAX doesn't have as much gain for VHF-High as your previous antenna had. But, since you had trouble with WVEC 13 before, maybe something else is wrong.
Are you using a preamp now?
You have some strong local FM transmitters that might cause interference to the reception of WVEC.
http://www.fmfool.com/modeling/tmp/3...e/Radar-FM.png
An FM filter might help. I see that the Antennas Direct FM filter is no longer in stock:
Since Antennas Direct was the last regular supplier of FM filters, I don't understand why they discontinued it.
If they brought it back in stock, they could charge 2 or 3 times as much to make a good profit. Making it available would encourage people to buy their other products.
If you can't find an FM filter from other sources like eBay or Amazon, then a HLSJ can be used as an FM filter.
https://www.solidsignal.com/pview.asp?p=zhlsj
If that doesn't work. you might have to add a dedicated VHF-High antenna to your CS4MAX and combine them with a UVSJ UHF/VHF combiner.
