Update: Without going into the attic yet, I put a new 4-way splitter with a built in ground block on the main coax coming off the attic antenna. Currently I only have the bedroom hooked up to this antenna, but eventually would want to add 3 more locations (all very close) Living room, dining room and another bedroom. I hooked up the ground screw to a #12 ground wire going to the main panel of the house. I saw NO issues on WCCU after doing this. HOWEVER I lost all channels on WAND 17 and WBUI 22. I took off the 4-way splitter and put on a 2-way with same ground and everything came back solid, no issues on any channels. I'm guessing I had a bad splitter OR is splitting 4-ways degrading the signal so much I'm loosing everything towards Decatur?
