Old 12-Mar-2018, 6:41 PM   #10
skatingrocker17
Originally Posted by Spencer View Post
The reason I was asking about the 2MAX is that there is also WJBK on VHF 7 on the opposite side of WJRT 12.
Also for the past 2 days WJRT has been coming in great. Weird.
I have used the VHF kit on the DB4e at 2 locations and have been able to receive WJBK at both. The first was in Canton ~17 miles away and the second location about ~3 miles away. I was also able to receive WJBK reliably with a flat antenna too even though it broadcast on real channel 7, the signal was strong enough that I've been able to receive it without issues. Even at 38 miles, you may be able to receive Fox 2 with the VHF kit but if not you may need an antenna with more VHF gain (or separate, dedicated VHF antenna).
skatingrocker17 is offline   Reply With Quote
