Old 3-Mar-2018, 10:37 PM   #5
mars1162:
Yes, I also would like to see your TVFool signal report to help me understand your reception problem and learn a little more about the Televes preamp that has AGC.
Originally Posted by mars1162 View Post
WFIE is not showing on my channel search on TV Fools signal strength map with all the other stations in my area. It is about 13 miles from my location. Their tower is located in Henderson KY on Wolf Road. It is listed locally as channel 14 on a 1000 foot transmitting tower. It may really be on channel 26
You are correct, it isn't on the TVFool report. I picked a location at random in Henderson:
http://www.tvfool.com/?option=com_wr...9038260d5e86fe
and then I used the same location for a rabbitears.info report which shows WFIE NBC (the page takes a long time to load when signal strengths are requested):
https://www.rabbitears.info/search.p...=dBm&height=25
