Old 3-Mar-2018, 8:47 PM   #3
mars1162
Thanks for the info Rabbit73 ! One of the reasons that I decided to try this antenna was the passive amplifier! I think it is the only one I have found as of yet that the preamp mounts at antenna and you can still turn off the amp or not. I have not tried heading antenna in the direction of further stations with the power to amplifier off to see if this corrects the problem of stations signal strength being to one side of antenna . I will try that shortly. The last antenna I tested was denny's HD stacker and did not have that problem with it BUT I did not have it amplified.
mars1162 is offline   Reply With Quote
