Old 2-Mar-2018, 3:45 PM   #2
jrgagne99
You have some pretty decent signal strengths. An indoor antenna might work, especially if the window you're putting it next to faces east. You will probably need a VHF element to get your ABC. There is a chance it will come in on a UHF-only rig, but I almost doubt it. I recommend a Clearstream2V, 1V, or 2MAX/1MAX with the VHF kits. I don't think you will need the 4 UHF rings, but ADTech might chime in on this.
