Old 28-Feb-2018, 3:17 AM   #4
Good advice from ADTech and Tower Guy.
Your FM signal report; the second strongest FM signal report I have ever seen:
http://www.fmfool.com/modeling/tmp/3...5/Radar-FM.png
Very likely to cause interference to TV reception.
You must ground the coax with a grounding block connected to the house electrical system ground to make the FM filter (or two FM filters in series) effective.
Unfortunately, FM filters are no longer in stock at Antennas Direct. I hope they will reconsider their decision not to carry them anymore; they were the last remaining regular supplier of FM filters.
It is now necessary to scrape the bottom of the barrel, or use a HLSJ, high and line ports, that is also hard to find.
https://www.solidsignal.com/pview.asp?p=zhlsj
