The antenna is aimed in the correct direction, I went up into the attic to check it a bit ago. However, I think I got a couple of the signal issue items. It is a brick house (ground floor to roof), and the attic does have metal mesh on the sides (non slanted area) to animal proof the attic, as well as some metal meshes covering vents.
I also have a lot of foil backed insulation for the furnace in the attic's ductwork. Non of it touching the antenna, but still, lots of it within 10 feet.
There is 1 single tuner, this is my media center PC with Hauppauge 1250 ATSC tuner card. I do not need to tune more than 1 channel at a time, as all my TV's are connected to Media center extenders, so they all use the 1 machine to grab the TV signal.
