Old 8-Feb-2018, 3:23 PM   #1
PCoaster
Add 2nd antenna or a rotor?
I have a DB8e on a mast - elevated 7 feet above lower roof line - clear line of sight, I have a Juice Amp I point mostly to the Orlando towers.
I get most of the channels I want with the exception of CBS and NBC, these are either great (when they come in) or nothing at all. My question is should I use an antenna rotor to change direction when I want to get to CBS and NBC, since my other channels are just fine currently. I was warned in an earlier post that adding a second antenna can be tricky with signal interference, so I am not sure which way to go.
I appreciate any advice, and specific product recommendations (rotor,antenna)
My analysis: http://www.tvfool.com/?option=com_wr...9038a14234f9fd
PCoaster is offline   Reply With Quote
