Old 6-Feb-2018, 3:05 PM   #4
rickbb
You're signal at 100% but quality is only 56%.
This tells me to look at noise and/or overload. You're getting plenty of signal, just a crappy one. Or the tuner doesn't know what to do with it.
I couldn't use the CM7777 due to overloading, I went with a Wineguard PA100, (not sure of the exact model I'm at work and can't look it up now), it has an adjustable gain and I could dial it up to overload then back down to just under overload. Solved the issue I had well.
