Assuming you're after the Big-4 Networks + PBS, it would appear that you don't need any UHF capability because FOX is simulcast with ABC on WVII real-7. In fact, except for NBC, all the networks are on VHF-Hi and are not planning to move with the re-pack. The best antenna for VHF-hi is the Stellar Labs 30-2476. So if you can live without NBC, that is what I would recommend. If NBC is a must-have, you'll need something with VHF-low elements (i.e. HD8200, CM-5020, etc.)
The salty air you mentioned earlier is even more of reason to avoid a rotor, IMHO.
