Old 5-Feb-2018, 6:13 PM   #21
jrgagne99
Are you after PBS on real channel 10 from Calais? If so, you'll need to add a rotor to your shopping list. My preference would be to try to pick up PBS on real channel 9 from Orono- then you won't need a rotor. That will be tricky at NM=-10 dB, but is probably preferable to having a rotor up there. I've heard that rotors can be very prone to early failure, and your VHF-low antenna will be big and put even more stress on it.
If you receive PBS from Orono without the rotor-- Good.
If not-- you're only missing PBS... (although the Kid's programming is great if you have little ones).
