Old 5-Feb-2018, 6:05 PM   #20
Shareit4life
I just used something like these:
https://www.amazon.com/Solid-Signal-...na+gable+mount
Eeek! Ladders of 20-feet up to a fixed hunting tree stand is one thing. Adding more strap-on steps, with nylon straps that will invariably weather over time due to sun and wind seems very dangerous. My recommendation is to do your very best job on the installation with the cherry picker, and then call it good. It's not worth falling 40-feet out of a tree for TV. There's never anything on anyways...
I agree with you and will not even try if they are nylon straps. My friend said they come with stainless steel chains as an option to hook around the tree instead of the nylon straps which I was going to use. I am going to go actually look at them this week to see if its worth it and if they will actually last as the weather up here is brutal with the salt air.
Shareit4life is offline   Reply With Quote
