Old 5-Feb-2018, 5:48 PM   #18
jrgagne99
Originally Posted by Shareit4life View Post
For the gable mount do you recommend any in particular?
I just used something like these:
https://www.amazon.com/Solid-Signal-...na+gable+mount
Also I will be purchasing these
https://www.amazon.com/Guide-Gear-25...ds=tree+ladder
for the initial 25 feet from the ground up and then to sets of these to get another 20 feet.
https://www.amazon.com/Muddy-MCS1200...limbing+sticks
My friend who is a hunter has used the latter for years and they work great for someone under 250 lbs.
Once I have those setup I will be able to access the antenna easier if needed in the future.
Eeek! Ladders of 20-feet up to a fixed hunting tree stand is one thing. Adding more strap-on steps, with nylon straps that will invariably weather over time due to sun and wind seems very dangerous. My recommendation is to do your very best job on the installation with the cherry picker, and then call it good. It's not worth falling 40-feet out of a tree for TV. There's never anything on anyways...
