Thread: Signal Source
Old 18-Feb-2010, 5:00 PM   #6
mtownsend
Originally Posted by Birddog View Post
I am curious as to why the digital signal is sooooo much better than analog has ever been, and also why sometimes I get no signal.
It is because of the digital signal format. The content of a digital OTA broadcast is similar to the content of a DVD. As long as your receiver is able to lock on to the digital data stream, it can decode a perfect picture. If some of the data gets lost (like watching a scratched DVD), then you might see some video artifacts (pixellation, macro-blocking), hear audio glitches, or have the picture go away completely.
The cross-over point between a decodable signal and a non-decodable signal happens over a very small range. In other words, once the signal quality gets above a certain threshold, the digital data stream becomes 100% decodable, and when the signal quality is a little bit below that threshold, the data stream becomes 0% decodable. Since there is such a quick fall off from a perfect signal to a completely unusable signal, this is sometimes referred to as the "digital cliff".
If you have signals that sometimes show pixellation, or comes and goes when the weather changes, then it means that your signal levels are dancing around that "digital cliff". In a typical day, there are going to be natural fluctuations that cause signal quality and strength to vary. Things like temperature/humidity changes, heating/cooling of the Earth, blowing trees, weather fronts, seasonal changes, ground covering, and dozens of other factors can cause random ups and downs in your signal.
Choosing a good antenna and pre-amp will help improve your signal and thus give you more margin for error to deal with random signal fluctuations. If you have more signal margin, then you are less likely to see any pixellation or drop-outs.
I wonder what a new appropriate antenna on a higher mast would do?
It sounds like some of the translators in your area are already operating digitally, but some are still running analog (channels 28, 30, and 48). I can see in the FCC database that channels 30 and 48 have already been granted permission to build digital transmitters. I believe that they are in the process of getting a permit for a digital version of channel 28.
Since you are currently experiencing some pixellation on two of your digital channels, then it's quite likely that you'll be able to clean that up with an updated antenna setup. A mast-mounted antenna on the roof usually works best (antenna about 5~10 feet above the roof). There's minimal benefit to going any higher than that.
At present, you only have one VHF station to consider, K09AK (owned by Eagle Nest TV Association). You did not report seeing this channel, so I'm not even sure if it's on the air. Eagle Nest TV Association also owns the transmitters for K48AX and K35BZ. I'm not sure if they have any plans to apply for a digital version of K09AK.
If your area has no more VHF stations in its future, then you can choose to use a UHF-only antenna. If you think there might be VHF stations returning to your area, then you can either use a combo antenna now, or plan on adding a VHF-only antenna to your setup later.
Your antenna choice will depend on how you want to deal with VHF.
