Old 3-Feb-2018, 2:57 AM   #4
Thank you for the more accurate report. To receive WLBZ NBC, you will need a BIG antenna that covers VHF-Low, real channels 2-6. There are four antennas currently available, the Winegard HD8200U, the Solid Signal HD8200XL clone, the Channel Master Advantage 100/CM-3020, and the Channel Master Masterpiece 100/CM-5020.
https://www.solidsignal.com/pview.asp?p=hd8200u
https://www.solidsignal.com/pview.asp?p=hd8200xl
https://www.channelmaster.com/Digita..._p/cm-3020.htm
https://www.channelmaster.com/Master..._p/cm-5020.htm
