Quite honestly, you have the wrong antenna. The DB8e is going to be of only little use for you.
Bangor ME has the distinction of being the only city in the whole country where a channel 2-13 antenna, if any still existed, would be all that's needed. With the DB8e, you should get WFVX-LD and maybe WMEB.
In any event, your plot appears to be based only on a zip code or else on an address that Google couldn't accurately geocode. Suggest you use the interactive map to pinpoint your proposed mounting location, set the proposed height, then run (and post) a new link to the new plot. That way, any ambiguity about location is removed.
