I would start by tracing the cable and doing a diagram of what you have and posting it here.
For example:
Satellite > 25 feet to distribution box > then 25 feet each tv (do full diagram with estimated measurements of cable lengths to each tv).
If there are more splitters after the distribution box, include them in the diagram.
Also post what type of coax cable was used. RG-6, RG-56, etc. It will say on the cable.
If you're lucky, you may have direct lines to each television from the one distribution box. If that is the case, and if decent cable was used, you might be able to re-purpose the cable for your OTA signals, sending the signal from a new distribution box only to the outlets where you have televisions.
