Old 24-Jan-2018, 8:43 PM   #11
Originally Posted by wreckbuilder View Post
great information Thanks, Yes I do have a tower and receive the Huntsville stations. I think I will try the 7698 Will I be able to combine the existing UHF antenna pointed at Huntsville and the new one and receive both markets? or maybe use a A/B switch because of the two channel 10 stations.
Any recommendations on Preamp
Thanks again
I'm getting confused, so I need to ask you some questions to give you an accurate answer, and look at the map above because I don't know your area.
Do you have a rotator, or do you want to avoid using a rotator?
Are most of the stations that you want, UHF stations in Huntsville and the only VHF station you want is in Nashville? If that is true, then you need a UHF antenna aimed at Huntsville and a VHF antenna aimed at Nashville. The two antennas can be combined with a UVSJ.
If it isn't that simple, the you might need the 7698 aimed at Huntsville and the 30-2476 aimed at Nashville with an A/B switch.
Can you give me a list of must-have channels by callsign and real channel number?
Preamps:
Antennas Direct Juice
Channel Master 7778
Channel Master 7777HD/Amplify; has HI and LO gain settings, but the switch is at the preamp
FYI:
WZDX will be moving to channel 18 because of repack
https://rabbitears.info//market.php?...&callsign=wzdx
WAAY to 17
https://rabbitears.info//market.php?...&callsign=waay
WAFF to 15
https://rabbitears.info//market.php?...&callsign=waff
