Old 24-Jan-2018, 7:08 PM   #7
Your TVFool report says antenna height 60 ft; do you have a 60ft tower?
Originally Posted by wreckbuilder View Post
What would be a good high gain VHF antenna to use with the 91xg.
and would this be a better setup than a single like the winegard 7698p
The best current VHF-High antenna is the Stellar Labs 30-2476.
http://www.newark.com/stellar-labs/3...vhf/dp/71Y5462
I'd say it was a toss-up.
You can combine a UHF antenna and a VHF antenna with a UVSJ, which is a low loss device.
The 7698 is a popular combo antenna for both UHF and VHF-High. With the 7698 you must follow the instructions with care when you unfold the VHF elements for max gain. The 7698 has a unusual method of combining the UHF and VHF sections that I don't like, but it rarely is a problem. There are forks on the circuit board that connect to the wires from each section with pressure contact. The circuit board is in the CB-8269 housing that can be replaced.
How To Troubleshoot a Winegard Antenna Cartridge Housing
https://www.youtube.com/watch?v=TlQk...ule1MX8jCAfvPQ
