Old 14-Jan-2018, 7:28 PM   #2
Welcome back, Eric
If you still want WJLP MeTV, then you will need an antenna that covers VHF-Low, real channels 2-6.
http://www.rabbitears.info/market.ph...&callsign=wjlp
Your signals are strong, but the report doesn't take into consideration the trees; it assumes your antenna will be in the clear. Trees block TV signals, so it is difficult to predict your reception results. If it weren't for the trees, I would suggest the Channel Master 3016/Advantage 45, but I suggest you upgrade to the 3018/Advantage 60.
https://www.channelmaster.com/Digita..._p/cm-3018.htm
I see a lot of trees in your area.
