Old 28-Dec-2017, 1:18 AM   #5
Originally Posted by s996kingsm View Post
I am currently using a 50 year old antenna in the peak of my attic.
Can you tell us more about your antenna, and maybe show us a photo of it?
If you want to try another antenna in the attic, I suggest a Winegard HD7694P aimed at about 115 degrees magnetic. Hopefully, there aren't too many trees in the signal path; trees block TV signals.
If the signals are too weak in the attic, add a preamp. If they are still too weak, you will have to mount the antenna outside.
