Old 27-Dec-2017, 7:03 PM   #2
JoeAZ
The TV Fool data base is missing information so it will be
making a few assumptions. I do not see all your major
affiliates listed, so I assume they are all relatively close to you.
Any antenna works best outside. You definitely should consider
moving your antenna outdoors. You have transmitters coming
to you from multiple directions. Under the circumstances, I
would recommend the Clearstream 2Max. It should do a good
job for you for most of your channels. If you do mount outside,
do not forget to ground your system. Hope this helps.
