Old 23-Dec-2017, 1:57 PM   #7
JoeAZ
Before you drill a single hole, I'd suggest you: have someone hold
the antenna where you hope to install, pointing the antenna in
the proper direction. Run a RG6 cable directly to ONE tv and see
if you get all your channels. If not, the person needs to move around
the roof and you need to perform scans to determine your best antenna
location. By the way, what is your zip code???
Be careful on the roof!!!!!!!!!!!!!!!!
