Old 23-Dec-2017, 5:46 AM   #6
A2J33P
I was mainly concerned about the transmitter causing problems, but it sounds like I’m good since the frequencies are so different.
I hadn’t considered the possibility of its physical presence affecting the OTA reception. Thanks for pointing that out. It’ll be mindful of that when we’re up there installing it. If it appears that I’ll be a problem in that location, I’ll move it to location B.
Thank you again, to both of you!
A2J33P is offline   Reply With Quote
