Old 22-Dec-2017, 8:15 PM   #4
A2J33P
Greetings,
The frequencies used for OTA television and Satellite Internet are
very different. I would not expect any interference between the
two. I would mount the satellite dish as far away as possible from
your antenna system. Those dishes can change OTA reception
patterns and cause changes to reception.
Thank you for the input, JoeAZ and AVTech!
Sounds like there’s no concern for frequency interference.
JoeAZ, I’m curious, when you say that the satellite dish antenna can change OTA reception patterns, is that simply due to the physical shape of the parabolic dish? It’ll be aimed 90 degrees from the direction that the OTA antenna is aimed; maybe that’ll reduce the physical effect?.
A2J33P is offline   Reply With Quote
