Old 20-Dec-2017, 6:45 PM   #32
JoeAZ
"So I took that plastic housing off the antenna (after unplugging the power supply inside) and there was quite a bit cobwebs and other bug "trash" in there. I cleaned it up, and after I got back down to earth again, I plugged in the power supply and turned the TV on. Everything is okay, but it may take a few days to see if what I did is helping any with CBS."
I frequently run into a situation as you describe above. In addition to cleaning
out the plastic housing, I also gently run some very fine sand paper or cloth
on the contact points and antenna lines where "contact" is made. It often
makes a huge difference.
I'm inclined to agree with Rickbb. When safe to do so, check each and every
outdoor connection point.
