Old 3-Feb-2011, 5:08 PM   #14
Originally Posted by bbarr View Post
ok I got you. But on the right end, the color spectrum changes quite a bit from the top right to the bottom right.
Also the color coding seems backwards when compared to what type antenna to use. If you are right by the transmitting tower is solid red.
If you are referring to the CEA color scheme, there is no correlation, either accidental or intentional between it and the colors used on the overlays and cross-sections.
