Old 20-Dec-2017, 1:47 PM   #2
JoeAZ
Greetings,
Based on the erroneous and often incomplete information on TV Fool,
you are receiving translators, about 7 miles from your location.
Most all of the other signals are far too weak for your antenna. You
would need to upgrade to something like a Winegard 7698p, a much
larger and capable antenna. Even then, you would not likely receive
all your major networks on a consistent basis. You would also probably
need a rotor to move the antenna between Portland and Seattle.
