Old 11-Dec-2017, 3:40 PM   #109
jrgagne99
Originally Posted by blackstone View Post
I have a second preamp coming.
I was thinking of using it on the DB8e mast for UHF and the second on the VHF line at ground level.
Does that make sense or overkill?
I don't think that's a bad idea. It sounds like you're talking about amplifying the VHF at ground level, upstream of the UVSJ. If you put the wall-wart and power inserter outside, you would probably want to build some weather protection/enclosure for them since they are not designed for outdoors. I guess you could put the wall wart and power inserter inside, but you'd need another hole in the house, or need to make your current hole bigger.
