Old 3-Feb-2011, 2:14 PM   #13
bbarr
Originally Posted by Dave Loudin View Post
That's why we stress using your exact location for best results. The height of the transmitting antenna is where the rays appear to come together at the left side, not the top corner. You are at ground level (more or less) on the right end.
ok I got you. But on the right end, the color spectrum changes quite a bit from the top right to the bottom right.
Also the color coding seems backwards when compared to what type antenna to use. If you are right by the transmitting tower is solid red.
bbarr is offline   Reply With Quote
